Gen 1 alignment problem
So I know I have some really bad inner tire wear in the rear of my brat. It's riding at stock right height And I have not lifted it or anything like that. And I can't seem to figure out how it would be that I could adjust this to eliminate the really negative Tire wear problems. Is there a way to adjust this? What about in the front as well?
guess subarus must never need alignments?:confused:
Hmm...Brat...I am not sure how much is adjustable on the rear. Toe should be, and you probably have too much toe-out, causing the inner side to be "dragged". Aim for 0.0 if you get an alignment.
It's also possible that a bushing is worn out or a suspension arm is bent. Get the car in for an alignment, the numbers usually help explain the problems.
