September 12, 201213 yr Has anyone used Enviro-Safe r134a refrigerant? I found a long list of reasons to use it such as cost and compatibility, and a couple of exceptional reasons not to use it. Mainly, it appears to have the same chemical makeup as propane which is probably something you don't want to have in your engine compartment should a leak develop. It's hard to find a review from someone that doesn't represent or sell the product. Thanks for your reply.
September 12, 201213 yr Yes, I use the "Industrial ES-12a" in both my vehicles that originally had R12. It works great. Nothing to complain about, been running it a few years now. Indeed it is a mix of propane and butane.
September 12, 201213 yr Author I should have mentioned it's for my 2001 Forester. From my understanding of its usage, it can be added to whatever existing R134a that still remains in the system. Thanks for your reply.
September 13, 201213 yr I really doubt that the efficiency savings is noticeable. I personally would just stick with regular R134a refrigerant since that is what your system is designed for.
September 13, 201213 yr I really doubt that the efficiency savings is noticeable. I personally would just stick with regular R134a refrigerant since that is what your system is designed for. Yes, I agree. If your system is designed for R134a, use that. If designed for R12, use the ES-12a. The reason EnviroSafe calls it R134a "replacement" is to skirt the laws regarding R12 retrofitting.
September 13, 201213 yr A while ago, there was a house explosion in NJ caused by a newer environmentally safe refrigerator operating on isobutane. Maybe it's best to use flammable refrigerants only in unattended industrial equipment, something they were invented for.
September 15, 201213 yr Author A while ago, there was a house explosion in NJ caused by a newer environmentally safe refrigerator operating on isobutane. Maybe it's best to use flammable refrigerants only in unattended industrial equipment, something they were invented for. I think you answered my question with that story. I'll stick with the standard R134a formula. Thanks for your reply.
