danzick Posted January 18, 2013 Share Posted January 18, 2013 so i have a few questions. i searched around and apparently im not very good at using the search function. the only write up i could find on a auto to 5 speed swap was for an ea1. my first question is, how the hell do you get the pedal assembly out? im not worried about breaking stuff taking it out of the old car, but i cant imagine how bad it will suck to put it back in if i cant even force it out. and i bought a donor car for 100 bucks. i have the whole car minus the engine so i should have everything i need right? what all wires do i need to jump/ re splice to make my reverse lights come on in reverse, and for it to start? Quote Link to comment Share on other sites More sharing options...
AdventureSubaru Posted January 19, 2013 Share Posted January 19, 2013 http://www.ultimatesubaru.org/forum/showthread.php?t=137481&highlight=ea82+trans+swap http://www.ultimatesubaru.org/forum/showthread.php?t=130254&highlight=ea82+trans+swap http://www.ultimatesubaru.org/forum/showthread.php?t=132475&highlight=ea82+speed+swap+automatic http://www.ultimatesubaru.org/forum/showthread.php?t=74863&highlight=ea82+speed+swap+automatic http://www.ultimatesubaru.org/forum/showthread.php?t=52234&highlight=ea82+speed+swap+automatic http://www.ultimatesubaru.org/forum/showthread.php?t=36505&highlight=ea82+speed+swap+automatic I've been researching the swap for an EA81 and keep coming across swaps within the EA82 body style. Read up on these and it will probably answer a lot of questions as you progress. Pedal assemblies can be tight, but should be pretty straightforward. Helps to remove the seat so you can lay on the floor to access bolts under the dash. Quote Link to comment Share on other sites More sharing options...
danzick Posted January 19, 2013 Author Share Posted January 19, 2013 got all the parts i could think of off the donor. so a few things that i havent seen covered very well, is what is the difference from the 86 carb model that im taking it out of an my 88 spfi? and what about the diffs. are my ratios going to be all wrong? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted January 19, 2013 Share Posted January 19, 2013 everything will be bolt-on. You will need the driveshaft along with the 5spd. all have a 3.9 diff except for turbos with 3.7, and all have 23 spline axle except for turbo 5mt and turbo 4eat automatic. The trick with the pedals is to remove the steering column. plug off the vacuum prt that leads to the vacuum modilator on the AT. after removing the AT shifter, jumper the 2 fattest wires in the middle of the connecotor to defeat the neutral safety. Quote Link to comment Share on other sites More sharing options...
danzick Posted January 19, 2013 Author Share Posted January 19, 2013 thanks for the info. how about trying to keep my 4wd light working on my cluster? id like to have it light up all 4 wheels like it does with the push button. Quote Link to comment Share on other sites More sharing options...
