March 26, 201313 yr The story of my DD brat... first part documented here http://www.ultimatesubaru.org/forum/topic/125445-time-for-upgrades-to-the-brat/?hl=%2Btime+%2Bupgrades the abriged version.... had a brat, drove the crap out of it, did a heap of upgrades, blew up the engine.... that was last summer. lack of time and money meant it has sat that way till now, i had a good core hydro lifter engine so am in the process of rebuilding that to get the brat back on the road i will keep updating as it goes, i am driving a cargo van at the moment so hopefully it goes pretty quick.....
April 2, 201313 yr Author got the engine dismantled, needs bearings as well, got them ordered. had to get the mains from rockauto - my local federated couldn't get them hopefully going back together this weekend...... also working on getting the interior put back together - installing "new" stereo....
April 3, 201313 yr Good luck with the rebuild. Is that your old Ford in the background? My daily for when the GL decides it's not happy is a '65 F100.
April 4, 201313 yr Author Good luck with the rebuild. Is that your old Ford in the background? My daily for when the GL decides it's not happy is a '65 F100. yea its a '64 F250 with a y-block, coolest truck ever - but its a b##ch to drive no power anything, its task is to hold a sign outside our fruit stand all summer. another week goes by...... starting to reaasemble now, at least thats a start
April 4, 201313 yr You have a great body to work with. Keep up the good work. I have to redo some gaskets on my Brat at some point this summer.
April 19, 201313 yr Author You have a great body to work with. Keep up the good work. I have to redo some gaskets on my Brat at some point this summer. thanks i work out...... sorry had to comment on that one back to reality got the block back together, crank and rods in also got old engine ready to lift out and got the stereo installed.....very important anyone have a brilliant idea for freeing up piston rings they are all good and not worn but gummed up and stuck in the grooves 2nd comp ring is the worst and i know they are fragile have had them soaking in gasoline fo a few days.....no dice hopefully back on the road this weekend
April 25, 201313 yr Author finnally got the rings to unstick.... soaked in berryman chemdip, got most of them 1 compression ring still stuck, boiled it on the BBQ for an hour or so in washing detergent, and a lot of swearing and poking got it to move... so pistons are all back in, old engine is out of the car, i am so ready to drive this thing again.... you don't realize how addictive they are.
May 3, 201312 yr Author got the engine in, but.... there was a freeze plug missing out of the head..... every one i talked to said they wouldn't have checked that either ahh well i get to install it with the engine in the car, that should make it more interesting should be able to fill it with oil AND coolant AND have the fluids stay where they are supposed to be the Subaru dealer had to "find" 20mm freeze plugs in a bin of assorted ones no-one else had them...... on the road this weekend...!!!!
May 16, 201312 yr Author the story goes on...... engine i put i lasted about 14 miles........ don't know if i did something wrong or if there was something wrong with the engine that i didn't check..... ahh well either way ...... bought another RUNNING engine and am having a subaru master tech install it for me, should be back on the road in the next couple weeks
May 29, 201312 yr Author it's alive....... runs great, needs some carb tuning and need to "fix" the tranny mounts but its on the road
November 15, 201312 yr Author been driving the hell out of this thing - ready for winter got new tyres for the front - now i have the same size all round, 196/75 R14 found another set of rims for $40, so i can keep my wide ones dont look as mean as the 245/60 that were on the back - but at least i can run in 4wd paint job coming when i have some time during winter Edited November 15, 201312 yr by wallaby
