April 23, 200421 yr First of all i would like to say hello to all other soobie lovers out there. I have a twin turbo import motor from japan with ecu and wiring loom,many of the wires have been cut and i am desperately looking for wiring diagrams (for last 3 years!!). Can anyone out there please help? I have put the motor into a Vw kombi doublecab ute. Will post pics if anyone interested.Motor is running but idle control valve fault has come up and engine is hunting on idle.i will get there eventually but i need correct ecu pinouts to finish the fastest double cab in oz!
May 18, 200421 yr Author Can't anyone help at all ? I thought this was the ultimate subaru info site.
May 18, 200421 yr you may want to check out www.bbs.legacycentral.org and the www.rslibertyclub.org They are geared more for the first gen legacies....however they may be able to point you in a direction to get the wiring diagram you need.
May 18, 200421 yr Dude.. VW Kombi Doublecab.. You got pics? I think that is what we got as the Vanagon Doublecab.. Is it a syncro? Josh beat me to it, legacycentral.org is a good place to start.
