SPFI conversion engine harness
tweety
Making progress with some issues with my conversion SPFI to ea81.
I have a code 35.  Purge control solonoid.
The SPFI kit had two resisters.  One resister was connected to the EGR solonoid Valve connector- two wires- blue/red stripe and Black with white stripe.  The second resister 67 ohms, wasnt connected.  There is a connector on the harness with two wires- green/blue stripe and black/white stripe.  The green/blue stripe wire corresponds to number 5 on the middle sized ECU connector so it confirms its the Purge solonoid valve connector.
The spare resister connector doesnt fit the purge connector.  I assume I can cut off the resister connecotr and fit two spade terminals to fit into the purge connector? Then that I also assume will fix the eCU code and fix the issue.
Can anyone confirm this?
A few days off and I'm feeling like doing a bit on the trike.
Made up this board.  Fitted female connectors to the injector, MAF and Throttle sensor.  Then 5 feet of wiring to this board.
So trike sensors can be monitored as we ride it.
Note female connectors.
This resister was in place on the kit as part of the TB harness.
This plug was vacant and is the purge solonoid connector. so a resister has now been installed on that.
Code 35 now gone (purge).  Code 31 (throttle sensor) still going but havent tried to cancel code yet.
