91 Loyale Fuel Reset Button
Today I totaled my brothers 91 Loyale. I doesn't start. the cops that did the accident report were asking if I new where the fuel reset button was. I told them I didn't think it had one. Does it have one and if so, where is it.
To the best of my knowledge, no there is no reset button.
In what way was it totalled?  Where it was damaged could indicate why it won't start.  Otherwise, look for what is missing:  Compression, spark, fuel.
It was hit on the front right corner and the car was spun around and hit again between the rear right tire and the gas door.
Could have severed the connection to to fuel pump. The wiring harness for the pump runs in that quadrant and the pump itself is located infront of the rear tire.
Connecting the green connectors in the engine bay will cycle the fuel pump on and off when you turn the key to the on position.
There's no fuel cut switch.
I'll bet the timing belt got snapped or some wiring for the ECU/fuel system got damaged.
I didn't think it had one, when the weather warms up we'll try to get it running. My brother wants the motor for his other Loyale with 300K miles. This one has 112K.
