December 14, 201312 yr Hello NorthernWestern! i know that; EJ's motor mount seem cant fit on GL's cross frame. so, have to do drilling for hole? or have to take off the legacy cross frame swap to GL? or give me correctly advised. **I could keep bother you guys for our project but i really like to make it for my goal. P.S. im hearing impaired which is my English grammar is my 2nd language. thanks
December 14, 201312 yr EJ mounts DO fit right into the GL frame. All my swaps it's just dropped right in.
December 14, 201312 yr The hole spacing is the same, but the angle is a bit different. When you tighten the nuts the mounts are stressed. Probably not an issue for most softer mounts, but I heard of people tearing the STi mounts, so I bought some small aluminum wedges that correct this angle.
December 14, 201312 yr They sell camber wedges for for adjusting the angle of a solid axle bolting to leaf springs that can be trimmed down to fit. I just ran the mounts the way they were. I think one tore eventually but they were old mounts and I beat the piss out of the car so...
