trouble with weber DGEV 32/36
I cant get my car to idle at all... there are no vacume leaks... checked that.. it revs up ok, but when it is supposed to go to idle, or when it drops down to the low (under 2k) rpms, it runs real chunky, and studders.... I looked down the primary barrel, and where the fuel is sprayed out (the jet outlet?) it is a wet dribble, not a mist like it should be- I cleaned out the whole carb (took out all the jets and cleaned the whole thing in chem dip) and put it all together, and it did the same thing...!!!! could something be broken, or worn out??
i am having nothing but trouble with this carb.. and i am tempted to go back to hitachi! (never had this much trouble!)
any ideas or suggestions? my wagon is dead untill this is solved!!
