January 17, 201412 yr Hello. I'm an old member, but I lost my information to the site. I'mlooking for a wiring diagram for a 1991 loyal standard transmission. Ibought this car off my brother, he took the transmission out of it andput a dual range standard transmission in. I had no revirse lights so ihad to do a bypass on that but the 4wd light on my dash never workedand a year went by and i traded the dual range up for standard turbotransmission from a 87 gl 4wd and did a bypass on the 4wd light for thedash, now its always on when im in gear, and its off when im in neutral,weither I'm in 4wd or not i have looked for wiring diagrams to find thecause of it not activating right, but no luck, can anyone help me out,pictures would be great, with a diagram. Thank you. Looking for information about the switches on the transmissions to help figure out what is going on. My name is Matthew Jackson
January 17, 201412 yr Hey Matt, Ill see about getting a scan of my 91 FSM on the NPS/back-up switches and the 4wd switch. Should be the same hookup from any of the ea82 std. trans
January 27, 201412 yr Author hey, i figured it out, got my FWD light working right, so i don't need that wiring diagram anymore, but thanks for the help,
