January 28, 201412 yr 2000 Legacy L. I did a fair amount of reading, but had a question or two and thought I would try to get things in order since I may only have 1 shot at this (temps finally getting into the 30's this weekend). I've got a pretty solid leak from the bottom of the p/s reservoir, most noticeable on the pass subframe. In addition there seems to be either p/s fluid or oil on top of the pass. side head. The low pressure hose on the top of the pump and high pressure hose (has o-ring which is apparently a common leak) aren't leaking (at the pump at least). I don't think the sensor is, but need to double check (if it is, it's only a drop). Does the pump leak underneath by any chance? My plan is to replace the suction and return hoses (34611AE08A,34611AE09A; which seem like dealer only), and probably the o-ring. Anything else I should check? PCV valve and hoses are clear, guess I need to check the breather on that side though. Thanks for the help!
January 28, 201412 yr The pumps are fairly easy to rebuild. If replacing the lower reservoir o-rings doesn't fix it rebuild the pump. Engine oil leaks are common as well. Valve cover gaskets often leak all over the subframe.
January 28, 201412 yr Author Thanks, that's def good to know. Are there o-rings in the bottom of the reservoir? Doesn't appear to be any in this pic: http://opposedforces.com/parts/legacy/us_b12/type_2/steering/power_steering_system/ VC's are in OK shape, don't think they're leaking on top of the head. I guess the back of the pump housing comes apart? Maybe it's leaking at the bottom of that and I can't tell.
January 28, 201412 yr Ah I see you have a separate reservoir. The older ones had the reservoir right on top of the pump with an o-ring to seal the two together and a rubber coated washer inside to seal the bolt that holds the reservoir on. Yes, the case seam does leak on these pumps. That will require at least a partial rebuild to replace. The rebuild kit comes with all new seals, but the front seal is only replaceable by pressing the shaft out, which requires a new bearing, usually not included wih the kit. IIRC is is a standard 6203 rubber sealed ball bearing which is only about $5 at Napa.
January 29, 201412 yr Author Yep, it's off to the side. Excellent info, thanks. I'm 99% sure the front isn't leaking, but will tear into Sat morn when there is some actual light out, and the temp isn't 10 degrees.
February 2, 201412 yr Author Well, I'm 1 step closer. I found the oil pressure switch is leaking prettttty good. It's only like a 15-20$ part, so I'll probably just pop for a new one. Switch works fine as far as i know; any way to just reseal the existing one? Seems like maybe it just uses an o-ring?
February 2, 201412 yr If the housing is leaking it needs to be replaced. No fixing that. If the threads are leaking you can pull it out and put thread sealer on it. The threads dont typically leak though.
February 4, 201412 yr Author Thanks Fairtax, appreciate the help with this. I took it for a ride and after popping the hood there was oil "flowing" out of the top, and the threads a bit. So I'll replace the whole thing, it's cheap enough.
