February 18, 201412 yr About a week ago, during our most recent deep freeze, my heat selector switches stopped working. (Defrost, Vent, Floor, etc..) From my reading around the board, I gathered that it's a vacuum issue. An issue presented itself to me right when I opened the hood: This is the vacuum canister right? Goes from the engine, across the firewall then down into the cab from there. So I'm confused because my selector switches have worked since I've owned the car, but this loose hose appears to just be sitting there, there is no other hose coming from the intake that mates up to it. Or even a bare vacuum port on the intake, they're all plugged. So I guess the question is, is this my problem? Thanks!
February 18, 201412 yr Author Just found the other end hanging loose behind the engine, it was hiding a bit. Today I learned even more, to investigate further on the car, and on the site, before posting. This thread can be deleted.
February 18, 201412 yr Might check the plastic line across the firewall if this doesn't fix it. Mine had a pretty bad abrasion in it. John
