Cones and spring washers
Mine are exhausted.  Anyone have a good place to get these...if you still can?  The NW would be handy.
subaru dealer, whichever is nearest.  you could pull some from a junk yard if then look good, but technically you should be replacing them with new ones when you do axles.  the cone is called the "Center Piece Axle" if you call a subaru dealer.  once they find it on the diagram they can see the part number for the spring washer as well.
I got mine from the dealership. For you Washington people, Chaplin's Subaru/Volkswagen in Bellevue has some knowledgeable people in the parts department. They found it within a couple minutes. Ordered two cone washers and two spring washers. Total was like $50 or something, but they took 25% off because they messed up on the shipping (twice).
Seriously, Chaplin's is great. Somehow they found the part number for those "paper clips" holding the throwout bearing on the clutch fork. They found it within like 90 seconds and they had 'em in stock. I was impressed. Super friendly people too. High recommendation.
Sorry, a little off-topic tangent there. ;)
Ok.  I dont have a Soob dealer and I dont have a junk yard.  I was thinking there would be an online vendor someone might know of.
check with Shawnw on this site.  He has a shop in Colorado and ships axles and such.  he may have a few around or be able to get some in.
Will do...thanks.
Ordered some...end of story.  Thank you.
