92 Legacy lock cylinder.
So, my Legacy's lock cylinder on the driverside broke last week. My question is, what models are the same? I am willing to strip it and rebuild the one that's in it, and keep my factory tumbler set, I just need the piece that actually moves the locking system. If any of you know the answer I would be grateful. Mainly because it would keep the girlfriend from complaining. Which to me is a definite plus.
I'm not sure how the lock cylinders are on these, but most just have a nut on the end that holds a lever. Loosen and remove the nut to remove the lever and swap it to the original cylinder.
That's the way that I thought that it would work. I've had the one for the trunk apart before, just wasn't certain on the one for the door. Thanks.
