idle jump at steady rpm
I desperately need help. If I hold my car at a steady idle of about 2500 it will drop down about 100rpm then go back to 2500. Just changed spark plugs and gapped to 1.1mm also put a new dist cap. The idle is also very low.
When I drive once it gets past the 2500 mark its a sudden burst of power.
Car is mpfi ea82t
Also no vacuum leaks and recently changed intake manifold gaskets
Could the culprit be knock sensor or 02?
