July 10, 201411 yr Im looking for a new throttle cable that will work with the linkage adaptor that comes with the webber carb kit... I cant seem to find one but im not really sure what to be looking for. Thanks!
July 10, 201411 yr Much easier to use the original cable and Subaru/Hitachi lever mounted on the Weber than mucking around with the generic bits supplied in the kits.
July 10, 201411 yr Author The issue is the factory mount is two low and the throttle gets stuck open... So i got the bracket that makes it level with the linkage on the carb but i need a throttle cable that can mount into it. Shouldn't be too hard since thats actually what its for. I just cant seem to find one
July 11, 201411 yr ATP Y631 fits the Gen 1 normal clamp style cable holder. It has a bare end, so you may need a cable clamp for the carb side end.
