Need to know which wires colors hook to ej22
It's 87 GL TBI;
I need to know; fuel pump wire is blue/red fuse box wire connect by ej22 wire (black/red)?
Want to see the fuel pump on.
Thanks
If you get the fuel pump wires hooked up and the pump still doesn't work, try grounding the fuel pump to the body near the pump. Mine wasn't grounding properly through the harness, but once I grounded it locally it fired right up.
Which hook up fuel pump wire on fuse box or fuel pump control relay?
Yes, of course.. I did put on ground wire.
Edited by Suba_GL_87
Personally, I just ran a new wire from the fuel pump to the black/red coming out of the fuel pump relay. I didn't want to mess with trying to find the existing fuel pump wire under the dash. I just ran it under the back seat, under the carpet and under the door trim. Not the cleanest way to do it, but it works..
