August 1, 201411 yr My cheesy CD service manual does not list torque specs for various repairs. Does anyone have handy the torque specs for: tensioner idlers water pump oil pump crank pully cam sprockets cam cap bolts thanks-
August 1, 201411 yr My cheesy CD service manual does not list torque specs for various repairs. Does anyone have handy the torque specs for: tensioner 18.1 +/- 1.4 ft-lbs idlers 28.9 +/- 2.9 ft-lbs water pump 7.2 +2.9/-0 ft-lbs oil pump 4.7 ft-lbs crank pully 79.6 +7.2 /-3.6 ft-lbs (although many tighten the crap out of this...more like 150 ft-lbs) cam sprockets 57.9 +/- 3.6 ft-lbs cam cap bolts top bolt 12 ft-lbs, bottom two bolts 7 ft-lbs) thanks-
August 3, 201411 yr Tighten the Crank pulley bolt to at least 140 ft lbs. Many times the torque specs are listed in the exploded views, but not in the repair sections. All of the torque specs will be the same for a Legacy. you can get a Legacy Factory service manual here: http://www.main.experiencetherave.com/subaru_manual_scans/ Edited August 3, 201411 yr by Fairtax4me
