September 29, 201411 yr I cant find the location of the fuel relay. Im not getting fuel to my carb and Im hoping I don't have to replace the pump. Does anyone have a picture of where it is?
September 29, 201411 yr It will be under the dash, behind the fuse panel, and somewhere between there and the steering column. I think all the ea82 relays are in a holder up behind the fuse panel. Hope that helps. If you do end up needing a new pump, I've got one from my car, just did an ej swap so I won't be needing it.
