January 27, 201511 yr Is the common for a 92 EJ 2.2 liter To burn an exhaust valve on number 1 cylinder because this car I just picked up hase 0 compression i the number one cylinder And 150 and all the rest Check the timing its good just fouls out number one spark plug or is it a slim chance that valve stuck or broken spring?
January 27, 201511 yr Not real common but it happens. I've had an E18 and an EJ22 in recently with burned valves. Pretty simple fix totally worth it.
January 27, 201511 yr I bought a 95 wagon with a burned valve on number 1. Engine had been overheated as well. Head gasket was blown out on 4 and I think it ran low on coolant which contributed to the burn. Whole cooling system on that car was a mess, except for the spankin new radiator!
January 27, 201511 yr Author So you think its the exhaust valve I'm almost certain that's what it is? I did a leak down test I heard no air coming back from the intake nor did I hear anything coming out of the oil dipstick it definitely sounds like it's coming out the exhaust I think more likely it's only one or two of them?
