front wheel brgs
 i have a 88 dl wagon and  i found out you can't tow without axles in. i am in the proccess of getting parts for the front end and have found all the parts except the front wheel brgs,they sell the rear brgs but i can't find the front set it got hot enough the rotor was glowing red hot and the hose broke and i found out brake fluid is flammible,probably the brgs  are bad but they turn ok,it would make me feel better if i changed all the brake parts because i think the calipers were sticking anyway or would it be prudent to get parts from the wrecking yard. i saw an 87 turbo at pull and save and was wondering if they are the same?
Easy, bearing belt and chain type supplier or ebay 6207-2rsc3\similar (open or sealed). Im almost posetive ea82 is the same bearings as ea81. You obviously need 2 for each side. Search 6207 on this forum and you will have all the answers.
