Parts for EJ Swap, Plus Some...
I'm buying a 93 legacy junk car. For an EJ swap into my BRAT, I'm pulling the following:
  • Engine
  • Motor Mounts
  • Wiring Harness
  • Power steering lines
  • Air box
  • ECU
  • Exhaust
Is there anything else that I should be pulling for the EJ swap? And I'm thinking this one is a "No," but is there any random stuff I should pull that is good for mods or fixes in an EA car? Any thoughts are appreciated.
I'm also planning on pulling all of the stuff necessary for a 5 speed swap into my brother in law's auto Impreza.
  • 2 weeks later...
not sure if the legacy radiator will fit. i have a later model impreza radiator. i would pull it and see. Either way you cut a small amount of metal on top to slip in. Definitely go with a 2.2 radiator.
Also, take all smog stuff and keep intact. Lastly, pull fuse box from engine compartment for Relays such as AC
