Advice needed
My '98 outback Ltd is going in for head gaskets shortly, I'm buying parts in advance.
RockAuto lists a couple of timing belt kits for this application, Part # GTWP277A, and 277B, which seem pretty much the same but for what I think in the belt tensioner, 277A has an "integrated assembly", the 277B has a regular hydraulic damper.  I guess I need one or the other, but how to tell which without taking the front of the car apart?
Any opinions on the Gates water pump?  Should I skip the kit with the pump and buy an Asin pump (for instance) seperatly?
Already have the Soob headgaskets, from distant dealer.
TIA...
Gates kits are good quality. I've used their water pumps on many vehicles and had no problems with them.
More than likely you have the integrated type tensioner.
The best way to see it is to remove the drivers end timing cover and look in from that side. You'll be able to see the end of the tensioner.
