June 7, 20169 yr Author The 98 Trans worked in the 97. New issue now. No brakes and running like crap. I did pull a MAF sensor code and will try the one off the Donor car in the morning. As for the brakes a steel line in the back was rusted and blew out. I am hoping to find a fitting at both ends and replace just the piece. If not I will have to get a double flaring tool and a couple unions and patch it. Not my idea of fun.
June 8, 20169 yr Author The MAF sensor off the donor fixed the idle. Now to find the fouled plug. Brakes and skip tomorrow.
June 16, 20169 yr Author Long story short. Replaced steel brake lines on rear to due them being rusted out. Brakes fixed. Running bad and IAC code. Replaced IAC, Ran good for a day. Fuel pump weak. Replaced fuel pump assembly and it took a few days but now running well. Actually running better than it has the 4 years we have had it. All the parts came off the donor car that provided the transmission.
