98 yes. 98 Forester has the same DOHC engine as the outback. A 95-98 2.2 is a direct swap. 96-98 2.2 has single exhaust port heads, and needs the single port exhaust y-pipe to match. A 90-94 2.2 can be used if paired with an intake manifold from a 95-98.
If it has EGR you at least need the manifold from a 2.2 with EGR to keep the CEL off.
