January 10, 201610 yr 86 gl mpfi ea82 previous owner apparently needed the wiring to do something instead of figuring out what was wrong... would love to get this rewired appropriately the four green wires end up here with only one connected to a light blue wire coming back into the car the divers side window functions well which is fine but we've got all winter to get this redone so far have not found the wires coming from the inside that go out the door thanks! Edited January 10, 201610 yr by Kbsubie
January 11, 201610 yr Author the plug on the left has power coming in on a red wire, they tapped in with the red white wire the plug in the middle has power at a blue/black wire was the green to light supplying ground? i have not found an empty plug, yet
