February 10, 201610 yr Between the Hi-Beam and Lo-Beam there is a bulb. Is that a Daytime Running Light Bulb ? And does someone have the Part Number ? Thanks !
February 11, 201610 yr Usually if its a clear bulb it's called a "City light" or something like that. 168 sounds about right. Should be a low wattage bulb, just enough to light up the reflector when the parking lights are on.
