March 14, 201610 yr So i found a 5spd transmission for a 1997 sti wagon will it work in a 1993 wrx sedan? one will it bolt up and two is the gear ratios the same? Edited March 14, 201610 yr by A_racing_driver
March 14, 201610 yr There's no such thing as a 97 STI or a 93 WRX. (at least here in the states anyway.)They both came later. Both Imprezas I'm assuming though... 97 transmission will bolt up to a 93 motor. Final drive ratio of the trans needs to match the rear diff. Get the trans codes off the bellhousing to check each one. Generally if equipped with EJ18 or Ej22 it would be 3.90 and if EJ25 it would be 4.11
March 14, 201610 yr Author There's no such thing as a 97 STI or a 93 WRX. (at least here in the states anyway.)They both came later. Both Imprezas I'm assuming though... 97 transmission will bolt up to a 93 motor. Final drive ratio of the trans needs to match the rear diff. Get the trans codes off the bellhousing to check each one. Generally if equipped with EJ18 or Ej22 it would be 3.90 and if EJ25 it would be 4.11 They are imported form japan
