July 18, 20169 yr Does it have to be 85? I have an 86 or 87, i would let go cheap, 86k, coming out of a wreck, roken timig belt, but ran til it broke the belt, im not in oregon but i dont want a lot, and i guess greyhound shipping is reasonable
July 18, 20169 yr Author not really as long as its carbed mine didnt have a computer and would the harness be the same
July 18, 20169 yr Author or if it comes with the computer and harness i should be able to swap it i think ill see what the pros on here say Edited July 18, 20169 yr by pbilt
July 18, 20169 yr or if it comes with the computer and harness i should be able to swap it i think ill see what the pros on here say Just swap on your carb'd intake and the distributor to the spfi block. The spfi pistons are high compression so you gain some power from that.
July 18, 20169 yr Author damn didnt even think of that that will work on all ea82s right so i can find any year
July 18, 20169 yr damn didnt even think of that that will work on all ea82s right so i can find any year Yeah just don't get a turbo block they're lower compression. You can get a mpfi block but have to swap on your heads for make a adapter plate for the throttle body. Carb and spfi are just bolt in if you didn't want to do the head gaskets.
