Which 2.5 block is right for my 2.2 heads?
Hey guys, I scored some single port EJ22 heads for cheap yesterday and got a loaded intake and the Y-pipe with it.
I figured I might as well go for a 2.5 block since I'm shopping anyways. Is there a certain one I should be using to match my heads?
Heres a link to an album with a picture of the heads in it: https://imgur.com/gallery/3Q4Eo
As long as the heads and intake are a set you can put on any EJ25 short block.
Don't use a 96 2.5 block or you will have to swap out the flat top pistons. They cause to high of compression and will melt pistons.
