engine mount location?
I just pulled off my oil pan on my Loyale so that I can put a new gasket in.
there is no way I am going to be able to put it back in without lifting the engine a bit!
could someone please tell me where the mounts are located and how many bolts I will need to take out?
sorry for the double post my computer keeps doing that
You also need to at least unbolt the stabilizer bracket for the engine so you don't break it. You should have enough room to not need to undo the exhaust. Don't use a cork gasket just use a sensible amount of rtv.
