95 impreza front grill
Hi This is Jerry, i have a 95 impreza GC8 and i want to remove the front grill i don't see any bolts to remove to get the grill off. Can somebody that has done this please let me know how to get it off, i don't want to brake it. Why the grill off i want to install my hella horns. Thanks Jerry
There should be about 6 total plastic clips that hold the grill on. I think it's 4 across the top and 2 lower. The top ones you can usually get a pair of needle nose and squeeze the release tabs in and pull out gently on the grill. The lower ones are a bit harder. Your supposed to be able to lift straight up on the grill, but the clips like to break. Subaru still sells all of the grill clips if they do break, but it's about $5 each.
