Sbimpreza Posted January 27, 2018 Share Posted January 27, 2018 Recently did a head gasket change as well as a resurface of the head. I put the engine back together by the book and now it won't start it only turns over. No fuel on the spark plugs and injectors aren't pulsing. No spark on the spark plug even though new ngk spark plugs and wires. Thought it might be the coil pack ignition so I replaced that(no dice). Thought timing was off so I checked that and after numerous engine turn overs the lines all line up on crank and cams. Replaced cam and crank sensors and still no dice. Double checked the fuel lines and they are correct. Only thing I came up with was that the wire connector going to the coil pack ignition only lit up in 1 of the 4 terminals when using a volt check light. Could my wire harness be bad? Everything looks fine on it and no major slices. Have no clue guys, so any suggestions I will try out. 1 Link to comment Share on other sites More sharing options...
