March 8, 20188 yr Curious, but just want to verify that factory ignition timing numbers are for sea level. I'm assuming so, but the tag under my hood (ea82 TBI) does say 20*BTDC +/- 2* (in green connector mode). Why the range if the ECU controls/adjusts fuel and timing while running? I'm guessing it's for altitude compensation. I'm at around 4,600' elevation. I can't really expect much for "performance" enhancements with this engine, but enhancing fuel economy is always a plus. I'm running about 18*BTDC right now, I think next fuel-up I'll advance to 20* and then to 22* on the following tank and see if the difference in MPG's and/or performance is appreciable. Cheers!
