1979 EA71 head gasket- HELP!!
Had head gasket go out in driveway. Didn’t get hot because I didn’t drive it far. So wasn’t concerned with warping. Put in new gaskets, torqued in sequence. I think it was 22 ft lbs, then 27 up to 42. Replaced intake gaskets as well. Stated up...still blew steam. Pulled plugs/ coolant in all cylinders :(
soooo was head warped? It so wouldn’t I just have coolant in cylinders in affected side? If intake or carb gaskets bad, how much coolant would I loose? Cause it drained quite a bit from radiator pretty quick.
need “short” term fix, maybe double gasket until I can get heads machined??
am I missing anything??
FRUSTRATED
Edited by MICHAEL1977
Added info
