August 8, 20205 yr Hey all, I'm trying to get this motor up and going. Currently, I am in a position that it will start, idle for for about 5 secs and then die. I can give it gas and it will respond (although a little delayed). When I run the codes, I get a P0123. The TPS has been reversed as I am using it in a subie - vw swap. Could the TPS be causing the motor to die ? Are there other common things that I should be looking at and for? TIA
