July 17, 200421 yr re: 1995 Legacy LS Wagon with moon roof. Problem: When it rains, water from the driver's side exterior moon roof drain hole soaks the interior headliner above the windshield under the visor, and travels down the A post behind the interior trim and drains onto the driver's side floor where the trim meets the carpet, which also gets totally soaked. This also happens to a lesser extent on the passenger side. It started this past winter after no such problem for the previous 8 years. How is this drain supposed to work? Is there supposed to be a drain tube running from the drain hole in the corner of the moon roof frame to the bottom of the car (when I probed the hole with a small wire, the wire appeared behind the interior driver's side window trim)? How might this problem be evaluated and repaired? Any references to documentation? Thanks in advance for any reply. Bob saltzman@nycap.rr.com
July 17, 200421 yr I think the rails that the roof slides in need to be sealed again. The drains are rarely the problem. I have described this somewhere on the forum before, if you search for "sun roof" or "Leaking" you should be able to find it.
