Transmission solenoids. Which one is a shift solenoid?
I'll keep this short. It's a long story. Suffice to say I did not do this damage. The car bottomed out. The transmission pan was dented. After that it did not shift while in drive. I think it's stuck in second or third. Reverse works fine. I took off the pan, banged out the dent then crawled back underneath and stared at all the solenoids in there. I checked a couple sources online and that was of no help. So I put the pan back on, put fresh transmission fluid in it but unfortunately there is no change. I'm hoping that someone here knows which of the half dozen or so solenoids is the one that controls shifting. It will not be cost effective to just replace them all. Thanks.
