Spook_G59 Posted Tuesday at 03:18 PM Share Posted Tuesday at 03:18 PM to start this car has 287k miles and about three years ago (a year after i bought it) it left me stranded in a parking lot. For about three months I had been dealing with fuel pump issues where i would have to "wake" it up by hitting it with a wrench to get it to run (also this is the only issue this car has given me up to this point), and in that parking lot it completely went out on me and wouldn't start no matter what i did. surprisingly after a few days of it sitting there i went back the day i was gonna get it towed to my house and it started! that was the last day that it fully ran and drove. i replaced the fuel pump, nothing. fuel pump relay, nothing. I only recently found out and confirmed that it was the wiring harness that goes from the relay back to the fuel pump. I was able to bypass the 12v power by wiring in my own spade connectors and wires and connecting the power to the fuel pump and that got it running with the turn of the key like it's supposed to. A new issue rose up with this though, now it doesn't want to idle at all, starts up tries to idle and stalls within seconds. I have cleaned the IAC with the proper cleaning products, i cleaned the air intake, bought a refurbished EGR valve, bought a junkyard coolant temperature sensor, cleaned the coolant temp sensor connectors to both male and female, still nothing. the only way i can get it to idle is if i connect the green test connectors under the hood and disconnect the coolant temp sensor completely, any other way it will not idle at all. I tried every combination of connecting and disconnecting those two and the only way is test connectors plugged in and coolant temp sensor not. i haven't left it running for long because i know you're not supposed to but this taught me that there is something here that i can fix i just have no idea what it is. i have scoured these forums for the answer and i have found nothing for this specific issue. I am now posting this as my last attempt at figuring this out and trying to revive my beloved car. Any suggestions and help is greatly appreciated, also sorry for the word vomit i just had to explain the amount of work I've put into this Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted Tuesday at 04:33 PM Share Posted Tuesday at 04:33 PM Does your ECU throw any codes? Link to comment Share on other sites More sharing options...
Spook_G59 Posted Tuesday at 04:53 PM Author Share Posted Tuesday at 04:53 PM 17 minutes ago, SuspiciousPizza said: Does your ECU throw any codes? the only thing it threw out was the EGR valve and that's why i replaced it, can't get it started long enough without fear of harming it to check if that fixed that code. Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted Tuesday at 06:46 PM Share Posted Tuesday at 06:46 PM (edited) The EGR code is for the EGR solenoid, not the EGR valve. The ECU can only read electrical faults, it will not know if anything mechanical is going wrong (the EGR valve is purely mechanical, as such the ECU won't tell you if it's dirty, sticking, etc) The solenoid controls when the valve gets vacuum. I've had this issue, it's an easy fix. Check out ('92 Loyale - Difficult to start, rough idle, and stalling/no power while in gear.), scroll to the bottom and it'll tell you how to install a new EGR solenoid. The solenoid will cost ya 50 ish bucks but you shouldn't have to replace it again. :] Edited Tuesday at 09:16 PM by SuspiciousPizza Broken link Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted Tuesday at 09:17 PM Share Posted Tuesday at 09:17 PM (edited) Shoot, sorry the link didn't work. Just look up the forum post, it's been recently discussed so you shouldn't have an issue finding it. Edited Tuesday at 09:17 PM by SuspiciousPizza Link to comment Share on other sites More sharing options...
Spook_G59 Posted Thursday at 04:30 AM Author Share Posted Thursday at 04:30 AM On 8/5/2025 at 11:46 AM, SuspiciousPizza said: The EGR code is for the EGR solenoid, not the EGR valve. The ECU can only read electrical faults, it will not know if anything mechanical is going wrong (the EGR valve is purely mechanical, as such the ECU won't tell you if it's dirty, sticking, etc) The solenoid controls when the valve gets vacuum. I've had this issue, it's an easy fix. Check out ('92 Loyale - Difficult to start, rough idle, and stalling/no power while in gear.), scroll to the bottom and it'll tell you how to install a new EGR solenoid. The solenoid will cost ya 50 ish bucks but you shouldn't have to replace it again. :] I got the part in today and just installed it, should fix the code but still hasn’t fixed the no running issue Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted Thursday at 12:18 PM Share Posted Thursday at 12:18 PM Have you flushed out the old gas or is this several year old gas? Also, have the fuel filters (all of them) been replaced? Is there sediment in the fuel tank? If you're not throwing codes and you were experiencing fuel issues, that's where I'd look first. The only bit that confuses me is the test connector/coolant sensor scenario. Have you tested the coolant sensor for the proper values? Hang in there :] Link to comment Share on other sites More sharing options...
Spook_G59 Posted 2 hours ago Author Share Posted 2 hours ago On 8/7/2025 at 5:18 AM, SuspiciousPizza said: Have you flushed out the old gas or is this several year old gas? Also, have the fuel filters (all of them) been replaced? Is there sediment in the fuel tank? If you're not throwing codes and you were experiencing fuel issues, that's where I'd look first. The only bit that confuses me is the test connector/coolant sensor scenario. Have you tested the coolant sensor for the proper values? Hang in there :] I replaced the gas a few months ago, fuel shouldn’t be the problem as if it was I wouldn’t see why it would work with the test connector and CTS situation as for an update on that, I tested the harness going to the CTS and found out I was getting no power which I would assume some current would be going through so I saw that as a problem, tried doing my tried and true method of going direct to power and then plugging the other part of the harness in to the CTS, haven’t found much success with that. Either I’m very wrong about how this sensor works or something is wrong with the harness going back to the ECU Link to comment Share on other sites More sharing options...
