1997 outback engine has burning smell
My 1997 outback has a burning smell from the engine after I have drived a long distance--100 miles or after going up a steep road. Car runs good after but smell " makes me thing something is wrong".
michael
michael
I had the same problem in my '98. Ended up having the seal on the oil pump changed (under waranty) Oil was dripping onto the exhaust pipe/header.
Stealer knew right away what it was.
I agree with mrtoyou7747. Before I replaced the front seals on my 93 Legacy, the oil would drip down on the exhaust and smell just awful. Since I knew what the problem was and that it wasn't hurting the car (as long as I kept oil in it) I let it go longer than I should and it ended up getting REALLY bad. It got to where smoke would actually seep out from under the hood and around the wheel wells after I stopped. I visited my brother-in-law once when the car was like that and he thought it was on fire!
I finally replaced the seals, then I degreased the engine. Now the leaking has stopped and the burning smell is gone. The car continues to run great.
michael
Thanks for all the help!!!!!!!!!!!!!!!!!!!
Going to have that checked!!!!!!!!!!!!!!!!!!!
Michael
