SVX pulling to right
Have a 92 SVX, bought new. It has always seemed to pull to the right, much more than would be consistent with the road camber. (It even pulls some to the right when in the left lane.) Recently bought new tires (non-directional), rechecked the alignment (it was fine), had the tires rotated to see if radial pull was the problems. Still no luck. In past, have tried varying tire pressures (higher on the side of the pull, lower on the other side - about 4-5 lbs differential - don't want to mess up the AWD or the handling). That seems to help a little.
Suspension and front end parts appear fine. Occurs while coasting as well as accelerating - so not torque steer. Have only about 62 K miles.
Any ideas or suggestions?
Alignments done at various places, in past, with generally the same result - essentially normal. This last one was done at NTB (national chain) by an experienced guy who seemed to know what he was doing.
