Just picked up spideyz's GL 10 turbo wagon
Ok, just got spideyz's GL 10 turbo wagon home. Threw a battery in it and sure enough it fired up. Drove it off the trailer into the driveway and began troubleshooting the car. Checked the radiator. Empty. Put some water in it and started it up. I instantly found the problem, yep you guessed it, blown head gasket. Water was just running out the right side of the engine. It was quite easy to see the problem when I looked under the car. Heck, it looks like the gasket is just about gone on the bottom where I could see. So I am planning to fix it. Tell me if I miss anything to replace. Here is what I am thinking so far. Timing belts, crank and cam seals, water pump and gasket, oil pump and seal and, the thermostat and gasket. Also, I figure I should have the radiator gone over since I will have it out any way. Let me know if I have missed anything or if I should do anything else while I am in there. Thanks.
Could somebody please move this thread to the older generation of subarus. I made a mistake as to where I put this one.
