October 21, 200421 yr Hi all! I am trying to get a new set of struts. I have received some very useful info from another forum but I am still wondering if anyone out there knows if I can put performance struts on my Outback Sport? Has anyone done it? If so, any brand you recommend or info you can give me would be great. Thanks
October 21, 200421 yr Impreza/Impreza Wagon struts should do you just fine. KYB/AGX or STi struts. Jamie
October 21, 200421 yr Author Do I need to be concerned about anything in terms of mounting. Should they line up the same? Should I take out the spacer that gives the Outback Sport more clearance? Thanks, by the way, for the quick reply - ur awesome!
October 21, 200421 yr basically they should line up the same. if you get full strut / spring setup - it should bolt right up. you can re-use your top mounts or you can buy newer/stiffer ones (they call them STi group N mounts) You will want to re use the spring seats if the setup you get does not have them. it's really not that tough wrx wagon, wrx suspension should drop right in. shout if you have questions! Jamie
