Guest Legacy777 Posted July 21, 2001 Share Posted July 21, 2001 I don't know where the original post is or who was asking, but here is the Subaru part #'s for the Trans filter kit, and trans pan gasket Trans Filter Kit # 21099AA091 Trans Pan Gasket # 21397AA040 Quote Link to comment Share on other sites More sharing options...
Guest Dale McGarry Posted July 22, 2001 Share Posted July 22, 2001 Josh Thanks for the part numbers. I believe those numbers are for the internal filter. My original post was about the external filter (looks like the fuel filter) in the cooler lines . Here is what my research has turned up so far. From Liberty Subaru, I found out that the filter comes in a kit or can be purchased separately. They told me that if I had a filter already it never needs to be replaced. That just does not make sense to me. What is the point of putting the filter in then? Anyone care to comment about that I would be interested to know why. Finally, I do intend to change my filter and here is the part number (31099AA031) for anyone else that is interested. Dale 91 Legacy L Sedan Quote Link to comment Share on other sites More sharing options...
Guest Legacy777 Posted July 23, 2001 Share Posted July 23, 2001 Hey Dale, No that part number is for the external kit. On the earlier legacies there is no internal filter, just a POS screen and magnet. That is why the external kit was added. I believe they revamped the newer ones with a filter. Not positive, but they did do away with the external filter. I can see them saying you do not need to replace the external one. Mine had about 140k miles on it. I decided to change it. It was like $20 for the kit. You can not buy just the filter, you have to buy the whole kit, which comes with brackets, hoses, and all that good ****. If you have the kit on there now, and you have high mileage, and are changing fluid and all that stuff too. I would just go and buy the kit and replace the external one you have on there. If you do not have the external one on there now, I don't know if I'd bother buying the kit to put it on. Because the tranny may have an internal one. That I am not sure about. If it does not have a "filter" and just a screen, I would buy the external filter kit. The other number I posted there is for the tranny pan gasket. You'll need that too if you change the internal filter or drop the pan. Any questions, just holler. Quote Link to comment Share on other sites More sharing options...
Guest remarcable Posted July 23, 2001 Share Posted July 23, 2001 The place where I took my car to have the tranny flushed put in a new filter (I have the 4EAT) and it cost me $40. I have no more specifics. Quote Link to comment Share on other sites More sharing options...
