November 3, 200421 yr Hey guys, This is my first post here. Question about the heater. I have a 90 legacy. The heater when turned on blows heat from the the floor only and not the vents above the radio. When I turn on the A/C there is air blown from the vents. Is this correct behavior or should heat blow from the vents above the radio also? If it should, what gives? Shekhar
November 3, 200421 yr If press the "heat" button it'll blow air at your feet and at the window. That's normal. If you press the "vent" button it'll blow air/heat through the vents in the dash. The "bi-level" button splits air between the vents in the dash and the floor. I'm not sure if that answers your question, or if you're having a similar issue where the buttons don't work right. The HVAC unit has some soldered pins on a circuit board where the solder cracks and the connection isn't there all the times. This will result in the vent selection to not work at all, and it'll just blow at your feet.
November 3, 200421 yr Author Thanks Josh. I think I should I have checked the manual first b4 shooting of this question because thats what the manual says. Shekhar
November 3, 200421 yr Yeah take a look at the owner's manual. It's got a lot of good info on the car in there. They really did a good job with it.
