November 4, 200421 yr Hi all: Can anyone help with details on aligning the camshaft and crankshaft pulleys so that I can replace a damaged timing belt on my '93 Justy? Also, does anyone know if the cranshaft pulley bolt is reverse-threaded (right to loosen instead of left to loosen)? I can't seem to get it loose! Thanks, Mike
November 5, 200421 yr Hi all: Can anyone help with details on aligning the camshaft and crankshaft pulleys so that I can replace a damaged timing belt on my '93 Justy? Also, does anyone know if the cranshaft pulley bolt is reverse-threaded (right to loosen instead of left to loosen)? I can't seem to get it loose! Thanks, Mike Last first: The crankshaft pulley bolt on my '88 is normal RH thread... can't believe that they would change it. What kind of help with alignment? BTW, it was pretty easy when I did mine (but it was on an engine stand. )
