December 5, 200421 yr hi i have the : http://www.msdignition.com/ Simple to install with no cutting or disconnecting wires. Powerful capacitive discharge sparks improve combustion for increased performance. Diagnostic LED confirms operation at a glance. Models for most any application from distributors, to coil packs and individual coils per cylinder. MSD Stacker Ignition, PN 7000 The MSD Stacker Ignition Control features MSD’s powerful multiple sparking, CD circuitry in a compact housing that is easy to install. The Stacker connects to your vehicle’s wiring without disconnecting anything! Actually, the factory ignition remains in place and the Stacker delivers a powerful CD spark to improve the initial ionization of the plug gap to improve combustion in the cylinder. The two spark profiles work together to give you a great boost in ignition power in an economical ignition control. Plus, since the Stacker “piggyback’s” the factory ignition wiring the ECU continues to see the factory ignition signals so there will be no check engine lights or tachometer problems. Stacker Ignition, Single Channel, Distributors PN 7000 For 4, 6 or 8-cylinder engines with a distributor, points or electronic. *Not recommended for certain Ford Escort|Focus|Escape models. Please call our Tech Line for more details 915-855-7123. OPERATING SPECIFICATIONS FOR STACKER IGNITION Operating Voltage: 10-18VCurrent Requirements: 1A per 1000 RPMRPM Range: 15,000 RPMSpark Duration: 20° Crankshaft RotationEnergy Output Max: 120 mJ 250VWeight and Size: 2.25 lbs, 6"Lx3.5"Wx1.75"HVoltage Output Max: 250 VoltsEXECUTIVE ORDERD-40-36 Stacker Ignition, Single Channel, Distributors PN 7000 + strong coil with MSD wires + iredium sparkplugs. i want to add or change other things for better performance in my car. can someone tell me or send me please information about what can i add or change . what will fit to my car if so. i'm talking here just about electrice parts, ignition system and other . thank you for your fast answer. moshe mina. the car is: subaru leone 1600cc year 1989 carborator with automatic transmission. thank you .
