Ignition Problem
Subaru '81 , turn engine on no worries , turn engine off keeps running. Any suggestions other than take it to an auto electrician? Thinking install kill switch?
try checking for burnt wires that may be shorting out in the ign circuit, around the coil
also check the pink clip near the passenger strut tower
if there is still volts to the coil it will run with the key off. if you want to fix this problem cheap put a switch between the + coil terminal and its power lead
Thanks Miles , will check it out
