January 12, 200521 yr Help needed. 98 forester just bought it. Runs hot, flushed radiater new antifrieze, after a run locally the plastic reservoir gets filled up and suprts out coolant. Could there be a headgasket problem? also changed the thermostat. Good heat coming from the vents. Anyone have the same problem, need a solution. Thanks
January 12, 200521 yr defo sounds like head gasket issue. have it sniffed for hydra-carbons in the coolant best get it checked out before dumping more $ in it.... Jamie
January 12, 200521 yr Have it sniffed for exhaust smell in the coolant. Was it overheating before or after you did any work to it?
January 12, 200521 yr Ahhhhh.... Did you try burping the cooling system? If not do a search on the board for burping...trust me. Try that first then get back to us.
