Phillip Posted January 31, 2005 Share Posted January 31, 2005 The seat foam (lower cushion) in my '99 Outback Legacy Wagon has worn flat from entering/exiting the car. Does anyone know of an aftermarket fix? The dealer wants over $100 just for the foam, and every used seat I've found has the same problem. Link to comment Share on other sites More sharing options...
mwatt Posted January 31, 2005 Share Posted January 31, 2005 The seat foam (lower cushion) in my '99 Outback Legacy Wagon has worn flat from entering/exiting the car. Does anyone know of an aftermarket fix? The dealer wants over $100 just for the foam, and every used seat I've found has the same problem. Is there an automotive trim/upholstery shop in your area? If the bottom cushion cover is not worn through, perhaps a trim shop could remove the cushion cover and add padding to the existing bottom "bun" (foam cushion), then reinstall the cloth (or leather) cushion cover...... Link to comment Share on other sites More sharing options...
